Anyone running 22x10 on leveled 99-03
Footz09
Acworth GA
Thinking of changing up wheels - my truck is a 2002 f250 4wd with leveling kit - was advised that I can run a fuel 22x10 with -13 offset . Just don't want nothing sticking out 100 yards from the truck . Can any give feedback info of this setup
Hmmm. That'll be gay. Find something in -25mm or get a 12 wide.
That offset would be ok if you were talking a 9 wide. It'd still stick out. I think the 10 wide with -25mm offset are just proud of the fender by 1/2". You are talking a 1/2 less offset....it probably will be right at the body line of even inside it a red c hair.
Footz09
Acworth GA
Wheel
I would think -25 would stick out further then a -13 , that's if my understand of offset is correct - more negative ,the futher out .
It will. But im saying a 10 wide at -25 barely does. Barely.
My concern would be how the wheel is going to look. Be very little lip.
diezelfreak
Manchesthair tn
On my 04 the x12's stick out maybe 1.5" to 2" nothing major which is how I like it. I would think like TyCorr said a x10 with a -25 will sit flush with the fender.
Sent from laying in bed
jameson731
johnson city, ny
I just took 22x11 with a -24 off of my 01. First pic is to show you the stance with that setup. Second amd third pic is of 20x10 with a -25. Fourth is of 20x10 -19 which i didnt have a strait on pic of but you can still see the stance. On the 99-04 you wont have to worry as much about the wheel poking way out because the front end is i believe 2" narrower on each side then on trucks with coil spring fronts.
Footz09
Acworth GA
The 22x10 with the -13 offset will be a half inch tucked further then the 2 pics i posted above of the 20x10 -25
Which is really the look I'm wanting - the -25 looks to not stick to far away ,maybe what 1.5-2" ? If the the 22's with a -13 offset would be 1/2 inch more in then that's really what I'm searching for - thanks so much for the great info with pictures
INSANE
Florida
I am running 22x10 (-24) Fuel mavericks with 35x12.50r22 Fuel MT Grippers on my 01 F350 and they only stick at maybe an inch. The set is for sale if you are interested. They have around 500 miles on them. No scratches or curb rub. Like new. Pm if interested.
1stock13
I'm looking at the Fuel Crush wheels, 20x10 -19 and running my 35x12.50 on them. I don't have extra fender flare so I think it should look about right. I don't like the skateboard look personally
And you wont get it with any 10 inch wheel on a 99-04 body style superduty. A 12 wide on a 1st gen sd looks like a 10 wide on an 05+. In terms of stickout. Obviously the wheel itself doesnt.
This was years ago but that is a 20x12 -44mm offset wheel on a 2000 f250.
