WydOpen
If so, please post up some pics and your review/thoughts.
Thanks! :toast:
Thanks! :toast:
The front springs are icons 7inch lift springs.
I have the 7" alpha lift with the stage 3 no gusset traction bar blocks, bilstein 5100 shocks, the long arm 4 link, hd solid mount track bar, and the dual stabilizer kit with bilstein shocks. I love the setup the only regrets I have is not going taller and getting better upgraded shock. The ride is pretty good to be a little bumpy but that is more cause of my tire setup 37s toyo mts and 22s with a good amount of air pressure.![]()
Hey peont
I'm looking to get this same lift.. I have a 2014 f350 Platinum What all came with your lift? Does it rub at all? And what offset or tires are you running? Truck looks great btw.
I noticed that you have a B&W turnover installed on your truck. Can you still pull a gooseneck with this lift? I was worried about that and decided to go with the 4.5 Icon lift. But could always go bigger!
