Binder man
- Joined
- Jan 6, 2013
- Messages
- 681
- Reaction score
- 0
Anyone have any experience with SEN amps? Had a buddy give me on awhile back SEN 21100. Suppose to be 1100 Watt. Are they worth a darn?
honestly, probably not, it will probably put out some DIRTY ass clipped power. if you do already know about audio, dont take what i say next to offense. a list of good amps/ car audio would be sundown( extremely good products), jl (way overpriced), crossfire, audioque/digital designs( made in same warehouse/same product) rockford fosgate(amps), kicker(amps), im sure i left some out. also, you want to rate an amp off of its rms power, not its peak power, say you have a sub that handles 1000 watts rms, you want to buy an amp that it rated at the same rms, or a little over if you know what youre doing, because the more you crank that gain up, the more likely you are to send clipped signal to your sub, which is what blows them, also, do not use bass boost at all. keep it at 0, bass boost is like a smoke switch is in diesel in relation to car audio, if your amp cannot make your sub loud without it, either you have the amp tuned wrong, a improperly designed enclosure, or you just flat out need a bigger amp
