Anything wrong with going 0.040" over?
Extended Power
Have a very bad feeling...and I'm probably pullin the engine out of the truck.
Tuning has not been stellar as of late, and bouncing off the rev limiter has left the engine with a "miss".
Trying to think of what it could be, but most everything is new...
-new Bulletproof 6 phase FICM, set to 58 volts.
-new hybrid injectors, ran smooth until bouncing revs caused a miss.
-new Schaffers oil, as per Jesse's instructions for his injectors....with two bottles of Rev-X added.
Anyone have anything bad to say about going 0.040" over? Since I'm already 0.020" over, I thought of maybe ordering Pistons now....
Extended Power
Thought maybe a pushrod jumped out, and causing the miss, but damn it's gonna be a lot of work tearing into it to find out.
Maybe a cracked rocker arm....
Zmann
you really only want to go over as far as you really need so you may have another turn later down the road
but if your looking for every ounce of power then 6.26 is a 40 over 6.0
Extended Power
Got another stock block here too, but thought about unshrouding the valves a bit more...
The block in the truck has already been re-honed once after being bored 0.020" over...thought I'd skip the 0.030" and straighten everything out.
Zmann
Interesting
I guess if the pistons for 40 over are readily available it would be the way to go for you
78f100
Bonifay FL
I didn't think 40 over pistons were available unless they are custom. I'm sure you have but all the push rods look good and straight? Did you compression test it yet?
edit: i was wrong they are available just found lots online.
Zmann
I thought 40 was available then it was custom ?
google ;-)
Extended Power
Haven't even pulled a cover off yet.
Still pissed off about it, and I go back to work again tomorrow.
Getting tunes through emails suck.:fustrate:
Hoping it would be something like a broken rocker arm, as the push rods are chromoly, and the springs have plenty of pressure to keep it from floating any valves.
The bitch still rips the tires off, but really...even down a hundred or so in horse power...it should...its just not idling smooth, and I can't take it on the highway, cuz when it locks up, the whole truck shakes BAD.
Extended Power
As an Amazon Associate we earn from qualifying purchases.
Extended Power
And I hate taking my truck to a dealership...
To be charged $150.00/hour to be told..."Nothing showed up on the scan tool...so we would have to tear into it until we found what the issue is"....is pretty much what I would do myself....tear into it.
nighthawk285
La Grande, Oregon
Lol you must live close to me. Anytime I go into a local parts house and machine shop needing anything performance related I get a full on deer in the headlights look.
Bustedknuckles
Take it to a shop and get a compression test done via a graphing lab scope and amp clamp. It will only take about 20 minutes and will tell you whether its mechanical or not and if so which cylinder.
Extended Power
Do they need access to the glow plugs?
How do they do a compression test without actually measuring the compression?
Not trying to be a smart a$$, just would like to know, thanks.
Bustedknuckles
It works by graphing the amperage draw of the starter. The lower compression cylinder takes less amperage to go past TDC on the compression stroke so you have a low spot on your graph. Pull the easiest to access glow plug which will cause a severe low spot on your graph and use your firing order to figure out which hole is the low one. Works like a charm!
Cutting-Edge Diesel
Newkirk, OK
Crank it over with out starting it and see how it sounds. Unplug the starter wire on the passanger side fender and jump it to the positive on the battery. But if I remember right you have compounds so your battery is probably on the driver side. Have to jump the wire or pull your FICM relay and crank it with the key. But that's the eaiest way to test the condition of the motor. Nice smooth crank means healthy. Hard spot is normaly bent push rod or really messed up bore. Fast spot is compression leak.
KCTurbos
I have run .040 on multiple trucks. There is plenty of meat. I have heard if you wanted to you could go .120 over and end up with a 6.4. There is the same amount of meat in both blocks.
I am running .040 mahle pistons that we delipped and cut custom valve reliefs on. Truck runs awesome.
Pull the oil fill cap and see if any of the cylinders are "poofing" more than the rest.
The other way like matt said is to pull the starter wire over by the passenger batter and touch it to the positive battery terminal. While turning it over listen to hear if any of the cylinders "sound" faster than the rest.
06f250powerstroke
ontario, canada
I'm in the same boat went to do an oil change and found a chunk of my oil ring try dfc for pistons there not far from you pm me your number we can chat via text if you want
Extended Power
One of the changes I did this last winter is installed a new starter....a 6.4L starter.
Boy do they even wheel the engines over quick!
I might take it in next set off, but I can't even drive it on the highway, as it shakes too much in overdrive. Don't really wanna phuk it up any worse than it already is.
Injectors are all new as well, so I can't see that being the issue.....and again...it ran fine up until the last time it bounced off the rev limiter a couple times.
Strokethis04
Use a temp gun and check the manifold on each cylinder to see what ones not as hot that one is missing and pull the valve cover off
