ATF question
hondahater4ever
I am coming up on 30k miles soon, and I wanted some input on brand of ATF when I change my tranny fluid. Should I stick with OEM ATF? I was leaning toward Amsoil ATF, whats your thoughts and opinions.
Kxc
South Jersey
LE all day for everything
jimdawg185
I do not want to go with that company. Going with a non OEM ATF is ok in these transmissions?
You require a rep from whatever oil company you purchase from to assure the oil meets a specific anti shudder thresholds, has at least a 40/40/0 @ 5 min 4146 and is at least a touch higher vis. LV is low vis, or around 28 cSt @40C I like our 1150 which is around 34cSt@40C. You're against using my product, however, it works so well you can use its testing slates as a guide if you want.
Let me know if you have any questions about power fluid testing slates.
hondahater4ever
Well you guys talked me into it, I ordered the Lubrication Engineers ATF. Still going to stick with Amsoil for my engine oil though.
hondahater4ever
Been using it for years and always had good results, my last diesel was a 2000 VW TDI I owned since 13k miles young went all the way too 378k before I sold it and never had any engine issues what so ever and used amsoil every oil change every 10k miles.
hondahater4ever
I am not saying it's not better, but the Amsoil did the job extremely well. I am in contact with jimdawg185 and getting some information on his motor oils but I am partial to Asmoil as of right now.
powerstroked08
Pennsylvania
I understand that your partial to amsoil. But that's not the question. What I'm asking is if there is a better oil than amsoil available to you. Wouldn't you want to use it?
hondahater4ever
Depends on price, availability, if I can see first hand how good it is over a a couple hundred thousand miles
dsberman94
Pennsylvania
Half this forum runs it. It solves lots of things that happen with these trucks that happen when you run store bought oil. I'd trust this stuff over anything else on the market right now as far as lubrication goes. And that's for everything, motors, trans, differential, equipment grease. Anything else jim sells, I'd buy, probably Girl Scout cookies too.
8WR_ZJ
Wait Jim seels cookies? Heck im down for a dozen boxes...
