toocoolpowerstrk
So i am getting ready to start a auto to manual conversion in my 02 f250 cc psd and i was wandering if the transfercase from my automatic will bolt up to the my zf6.
Shaft splines are different, but the driveshaft lengths are identical. I know this after getting that God-forsaken excuse of a transmission out of my truck and installing a 4R100.
I recently lost the one in the 550 as well. They can't take the towing. Good luck destroying a good truck by putting an inferior trans in it.
The truck will be slower, have reduced driveability for any given power and be capable of less continuous power output when towing due to trans overheating.
Facts.
I'm sure that won't even slow you down. It usually takes a year or two before the guys that do this learn the above facts the hard way.
Charles do you know what temps you had when towing and how much weight?
:whs: new shaft for the transfer case is about 200 iirc
