F-250-Owner
So, hopefully my streak of bad luck is over.... it started when I banged my truck up and had it painted, the Transmission went out the day after I got it from the shop. then a week later my engine went.... while it was down, I sent my injectors to jared at RCD and he went thru them tested them all, now I have 180/75s, with the DuraStroke turbo from Mad TurboWerks, FCDP EGR delete, Quick Tricks 58v FICM, a 50k 2006 engine with ARPS, OEM gaskets, Diesel Site coolant filter, GoGo Diesel shift solenoid. It runs pretty good now, I am running an old innovative tow tune with my PHP FICM tuner on the lowest setting until I get it shook down and all the bugs worked out. I need some tires and wheels.....I also have a couple versions of the Looney tune to try out, and a couple of tunes from PHP to run as well.....
