Backup Camera Issue
OOWeaver68
Southeast Texas
Has anybody had issues with the backup camera? Mine got a lot of static for a couple days, and didn't have a good picture. After that couple days, it started turning blue every time I put it in reverse. Been doing that for about 6 weeks I guess. Checked the connections at the tailgate handle and the one by the spare tire, they seem good. Is there any other ones? Has anybody had a problem like this? Just want to see what yall say before I start buying stuff that wont end up fixing it. Thanks.
tensixniner
I remember seeing a tsb about the rear camera.
The connection at the handle would either be dirty, loose or some of the pins would be bent/broken. Sometimes one or more of the wires in the female connector would back out of the plastic housing and not actually make contact with the male pins when inserted.
OOWeaver68
Southeast Texas
Ok, thanks. I made sure those 2 connectors in the back were connected good. And they looked fairly clean. Ill check on the wires. If that doesnt work, I guess Ill buy a new camera, or handle assembly, or however it comes.
