Bad accel pedal?
taterthedog
Canada
What are the symptoms of a bad accelerator pedal sensor? Yesterday, I was pulling out of a parking space in a parking lot and I had no response from the pedal. It would only idle along. I slowly gave it more throttle and it finally kicked in and was fine after. I checked codes and there wasn't any. Any thoughts?
Curious if they are acting insanely erratic or staying one value. Either or could cause the symptoms.
taterthedog
Canada
I've been monitoring 2 different app signals since it happened, but it hasn't acted up since.
Mesa, AZ
What sootie is getting at is a bad ebp can make the truck go into forc e d idle modes at times. It can also make it feel like it isnt accelerating due to command of turbos being base off ebp.
