bigwheel
I was in the process of putting my truck back to stock. Removed my stage 2's and replaced with a set of used ford remans. I can get it running in the morning when it about 50 but it stumbles and real loud. If I take the truck out for a drive before it gets up to temp, there is low power and shacks, almost feels like it missing. Once at temp it starts running way better or like it should almost feels like a switch got fliped to run better. There is a slight extended start time even when warm but it will start and run great.
Some things I have checked. No oil in fuel bowl. Changed out ICP with a good working one and no change. No smoke at start or running. I did take the truck to a diesel shop and he said injector #3 was out so replaced that one but truck still does the same thing.
So could it be another bad injector or 2? or IRP?
Thanks for any help
Thanks for any help
