MrMike2010
I have 2 forged chromoly 2.63" ballistic joints and 2 forged poly 2.63" bushings. I bought them to build some traction bars but I ended up buying a set from pmf instead. Have to check but I believe I have the jam nuts somewhere too.
The ballistic joints have a 9/16 bearing thru hole, the stud is 7/8 -14 tpi, left hand thread
The bushing have the same specs as the joint but they are right hand threaded. This way you can preload the suspension with the bars on the truck if you wanted.
Spent over $200 on these. Looking for $150
