Battery relocations how to- with pics please
West Virginia
Has anyone relocated their batteries to a different location other than stock? If so, could you provide pics, descriptions, or both of how you did it? Thanks in advance
West Virginia
Anyone at all? Even if its not a powerstroke... just some sort of idea what components to use etc. I'm pretty well set on using welding cable for the extension/relocation cables.
ingrahams
New Hampshire/Africa
Ballostic fab mount in place of the spare tire.
Kind
For my truck we tucked them up in the frame where the spare tire was. We built a bracket that holds them up, using the receiver bolts to secure the battery cradle. We also use the spare tire lowering/raising cable to assist in changing the batteries out.
It's far from pretty but it has been working just fine for the past 7 years.
taterthedog
Canada
Neat idea [emoji1303]
West Virginia
Not be naive but do you just mount the batteries where you would like, then run a new and bigger cable up to the factory power cables and make a permanent splice to them? Is there anything else that would need to change?
79jasper
skiatook, Oklahoma
Completely replace stock cables.
Most of the time a splice will lead to corrosion. (If not done correctly)
I like that idea using the spare tire winch.
There's many boxes/mounts made for relocating batteries.
I have a flatbed, so I plan to mount mine in a underbelly tool box. (When I get some lol)
