Best fuel sump
UNBROKEN
They're all similar..as long as they fit your needs and you install it right you'll be fine.
tchristman812
Following, I'm sucking air under 1/4 tank with my fass..
jcain
As far as I'm aware all of our aftermarket options for low pressure pumps re-use the factory suck tube and none of them require you to alter anything in the tank.
Even with my 50gallon tank with factory tube, I can drain the tank dry. I've done it on accident...
The tube should be able to drain a stock tank dry as well.
CMCx2012
Long Island, NY
Gary, I recently ordered the same (2) dual fuel setups. Got a nice deal from Josh on the parts!
My question is did you ever go with the catch can for the CCV reroute?
gfulton
Eliasville, Texas
No I haven't still venting to the atmosphere. Waiting on Mike or Steve to come out with a reliable and tested venturi kit............
CMCx2012
Long Island, NY
Oh, ok. I am going with Mike's CCV and then will have custom setup to catch can. I don't want anything to do with the negatives of running it any other way.
