Best way to level it out
woodduck97
Maryland
This is my friends truck and it has a 4 inch block in the rear and extra spring. She wants to make it level. My suggestion was to get a 6 inch block and be close to level or get a 8 inch and get a set of traction bars or just get a set of 8 inch leafs for it. What would y'all suggest to be the best way to lift it up? Thanks
Tom S
I personally think that the truck would look a ton better with the front lowered rather then raising the rear, with that size tires.
woodduck97
Maryland
I think it is a 8 inch on the front. She bought the truck the way it sits so I really dont know. What would be the best way to find out what size it is on the front?
Betarocker
Sea to Sky, BC
That'd be a hell-a-lot of block to run without a traction bar as axle wrap will be quite pronounced. If the leafs are in good condition still I'd consider a traction-block system, but those don't come cheap. The best is to figure out how much more lift is needed to get the desired stance and go from there.
Park the truck on a level surface. Measure the distance from the ground the top of the rear wheel fender arch and write down that number. Use a floor jack on the trailer hitch and lift until the desired height is attained. Measure at the same spot and subtract the first measurement from it. That is how much higher you need to go. Then add that number to the block installed. Come back with the numbers and then we'll figure out the options from there.
Just for reference, a 7" (3" hanger/shackle w/ 4" leafs) Icon lift measures about 31" from centre of axle to top of fender arch.
woodduck97
Maryland
Wheels are 18 inch mickey thompson classic wheels. Any suggestion I make is no good to her BF so I said **** it do what you want and jerry rig it. Here is a pic of her.
apollyon9515
wood did you say something in your last post? For some reason i couldnt see anything but the pic.....
Id probly try to lower the front if possible.
woodduck97
Maryland
Here is a pic of the truck after he put 6" blocks in and a add a leaf. (still un level) Also installed the wrong kinda of U bolts cause they were to big for the axle. He told me it was sitting level and he did all this great work and the axle doesnt wrap at all. But you can see in the pic it is un level and when he took off in it the axle deffentaly moved.
UPINSMOKE
Dundalk, Maryland
:doh:
Still not level?? Put an 8" lift spring in the back and see how close it gets... It does look better now than it did before.
