Billet wheel install question
blackcloudpsd03
I'm putting a billet wheel in my buddies truck for him. Here are the specs
Garrett GTP38 / 94~03 FORD 7.3L F250 F350 POWERSTROKE Turbo Billet Compressor Wheel 59.87/80.07 mm with extended tip diameter 86.2mm, Trim 56 / 7+7 Blade
Everything fits good but when you go to put the compressor cover on it gets right and you have to stop. And the wheel appears to be all the way tight . could be have picked up the wrong wheel?
did you measure the wheel or going off what it says it is?
blackcloudpsd03
I'm going to do that today. Didn't think I'd have to. It says factory replacement for stock turbo. What happens if it's taller it won't work correct. Like I said I still have to go back to the shop
