I changed both fuel filters and now I am getting a low fuel pressure light and it's going into limp mode. Pretty sure I got air in the system what's the best way to completely bleed the fuel system of air?
I do the lower filter first, cycle the key six times letting the pump time out each cycle. Start the truck and make sure doesn't stall.
Then change the upper filter. Repeat procedure above.
I've never had so much as a hiccup doing it that way.
Need help diagnosing my issues guys truck keeps going into limp mode and I'm throwing two codes p0093 and and another for over boosting (forget what the code is exactly). Any help would be greatly appreciated
If your referring to the Mexico tune it's technically OEM right? So it shouldn't void the warranty lol
