blowing a lot of unwanted black smoke
60powerplant
Sellersville,PA
Truck has a ts chip and with it on the stock setting its blowing a lot of black smoke! Tryed plug my scanner in and I couldnt get it to connect. Its powering up the scanner be keeps say no connection. Any ideas for the black smoke on stock setting? The power feels like stock to. Sorry tittle spelled wrong
JMart
DFW
Is it only doing this on stock? Is it a generic TS tuned chip or is it custom tuned?
TyCorr
unplug the chip.and tell us what happens, if anything. Try a.different tune? Same result?
JMart
DFW
Has it always done this in the "stock" setting. I am trying to rule out the fact that what you call stock my be a smoke setting. How does it act on the other settings? You didn't answer that.
60powerplant
Sellersville,PA
Ok I'll try pulling the chip tommrow. But if I change tunes it smoke about the same just the power is different on each setting. If it is the chip, is it the chip it self or the tunes? Can I just get a reburn?
TyCorr
We don't know. If it's smoking in all settings I'd.bet you have a nasty boostleak.
60powerplant
Sellersville,PA
Ok I'll check all the intercooler boots tommrow too. Thanks guys for your help! I'll get back to you guys tommrow with some results. Thanks again
TyCorr
Does it smoke without the chip plugged in?
He said he hasn't tried that yet. It smokes the same in all the tunes. For all we know, they could be the same tune in every position or six different ones. Sounds like a gigantic boost leak or waxed charger or immeasurable amounts of.each.
60powerplant
Sellersville,PA
Hey guys sorry for not geting back to you. I was looking over the truck before I tryied pulling the chip and two of the intercooler boost were riped! There was not clamped on the line to the map senser and the line was a loose fit! So put two new boosts on and some hose clamps on the map line. Truck runs good no smoke on stocking and some! Thanks everyone for your help
