blue smoke at idle
SDstroker
SE, SD
Did the smoke go away after you rebuilt the turbo? Does it do it all the time or just on cold start ups? Check your crank case vent to make sure there is no blockage. If turbo and CCV check out I would look at compression or injectors next.
kadeninabnitt
Martinsville, IN
Yea it quit after it was rebuilt. the only time I ever notice it is is in the morning on first startup and when i head out for the night from work. after a little bit of driving it stops.
Illinois
Did the smoke go away after you rebuilt the turbo? Does it do it all the time or just on cold start ups? Check your crank case vent to make sure there is no blockage. If turbo and CCV check out I would look at compression or injectors next.[/QUOTE
I agree. Mine did the same thing and it leaked oil just changed the intake manifold boots and cleaned the ccv a little and shes all good
