Yeah, I'm sure its a leak. When I'm just on cruise control it is always around 3-4 psi which is normal I assume, and when I get on it, it will build boost until about 10 psi and that is it. My boots do feel somewhat soft, so tomorrow I will be doing the CCV mod and then order some new boots. I'll also check the up pipes while I'm at it.
Here is a question though... How big of a leak would it have to be to only build about 10 psi? Could it just be a small leak, or would it have to be drastic?
Like I said before, I have great power, but the gauge says otherwise...
That is EXACTLY what mine is doing. Seemed to be running fine:
BUT,,,,made a detector, hooked it up and checked.
1) I had a leak in the right plenum boot.
2)I had a worse leak in the left plenum boot.
3) I had a leak in the
bottom hot air side I/C boot
4) I had a worse leak in the
TOP hot side I/C boot.
I took off the bottom I/c boot, cleaned (was already clean) hairspray and put back on. The clamp on top was a bit loose. Tightened it. The plenum boot clamps were very loose, I tightened them up just a bit, as I didn't want to damage anything. Gonna replace all 6 boots anyway. I didn't even re-check to see if anything was better. Got back up to 13-14 psi boost, so there is still problems. Hopefully I can remedy that with RiffRaff
