Borg 64.5 FMW turbo
scparrish
DFW Texas
Does anyone have any input on this turbo? Has anyone ran this turbo and a 66, not at the same time obviously? Just looking for some input on how this turbo performs, when does it start to spool and things of that nature. Also what injectors are you running with it? Thanks ahead of time.
Cutting-Edge Diesel
Newkirk, OK
Awesome turbo spooled slightly slower than a fmw 62 but faster than a 66. I think it made close to the power a 66 did but I didn't run them back to back only the fmw 62. Ran it with 205/75 injectors. Let me know if I can get you a complete package with that turbo!
bigrpowr
<How I Fly
Administrator
mine runs VERY well. makes about 625-630 on a 6.7 and fully lit at 2000 RPM .
strokin6L
Springville NY
With all the turbos I've tried....this one is something I'd like to try next. I ran a few vgt turbos(currently a KC 68mm vgt) and a couple non vgt's(62mm and 64mm). After hearing great feedback about the BW FMW turbos....this is one I'd really like to try out. I was pretty happy with the 64/71/70 non vgt....and I'm sure the 64 fmw will be better than that. How well will the 64 fmw work 190/75's? Also what size turbine wheel would this turbo have with the .83 housing? The 64/71/70 T3 I ran built boost around 1600-1700rpms. Will the 64mm fmw T4 setup spool better than the 64mm T3 setup?
JDub
Hooper, Utah
I think the 64.5/70/.91 or .83 is going to be a great option for the 6.0 crowd.
Sent from my DROID BIONIC using Tapatalk
swinky
Eastern, Nc
Any word on the 67.7 fmw? I've been thinking about doing a 371 as well.
Cutting-Edge Diesel
Newkirk, OK
any t3 .70 set up I ran I hated. It destroyed a 62 I was running too. But this was with compounds. never ran it as a single. Went to T4 and totally changed the truck.
strokin6L
Springville NY
Thanks for the feedback Matt! So do you think a T4 64/70/83 fmw would run a bit better than the T3 64/71/70 I use to run?
JDub
Hooper, Utah
Maryland did a 67.7FMW/70/.91 on a 6.0L and said that thing is a rocket, believe Greg said it was the best non-vgt option they'd tried yet. I don't remember which injectors they paired with it though.
I am looking for boost to come on a little more quickly than the s366 that I currently have.
The 64.5/70 is definitely going to spool faster than an out of the box 366.
scparrish
DFW Texas
I am hoping for great things from this turbo I ultimately want it to be a hp turbo if I like the spool up.
mattman347
Readyville TN
We are installing a 64.5FMW on a 6.0L here at the shop today with our 155cc injectors and Gearhead tunes. Ill let you know how it works!
strokin6L
Springville NY
Awesome....would really love to hear your results with the 155's. I'm sure my Full Force 190/75's would pair very well with this turbo. Thinking this would be a good start to compounds.
scparrish
DFW Texas
Price seems to vary depending if you want the .91 or the .83 housing. Not sure which would be better for my application yet.
