bottom end build!! what do i need
97stoker350
south central pa
Think I bent a rod the other day so just trying to get an idea of what I should do while engine is out. So far I'm looking at a half fil with maybe main studs, carrillos and a stage one cam. Block will be painted and all the bells and whistles. Help me out guys!
V-Ref
9 miles high @ 550 mph
Girdle?
Weld piston jets and cam gear.
Bung on oil pan for a atmosphere oil return.
Fire ring HG machining of block and head.
What made you think you bent a rod?
97stoker350
south central pa
No 100 percent sure yet but I was getting on it the other day and wen I let off I heard a real loud grinding sound and then it started knocking. Funny thing is there was no smoke out the exhaust just puffs coming out ccv. Getting a compression tester next few days to make sure
bruce
Middle east
I would be tryin to buy madman7.3 or whatever his screen name is. Pretty close to where you're at
