Brake Caliper Troubles
BigNiner19
South FL
Replaced the front drivers side twice, and the front passenger side once. The drivers side continues to seize up whenever I tow my boat. Is there a better caliper other than the OEM motorcraft that I have been using or something I can do to keep the caliper from locking up while driving.
adrianspeeder
I had a left rear seize on me at 60k two years ago. The composite pistons just crumbled. At 71k now with a Motorcraft replacement still working, and 8mm of pads on the other three corners.
Adrianspeeder
gabrielchartrand
Ya flushing works good. I also noticed that the pads are too tight know the caliper. I grind the caliper so that the pads fit looser.
Sent from my SM-G925W8 using Tapatalk
