Brake line blew behind the tank...
Godofdew11
all over
I now this is a common thing what have yall been doing to fix this? Who has kits? Im pretty sure im gonna try and get a 10' or so straight piece and go from union to union. put in the couple nessesary bends.
Thanks for looking,
Don
dustinz85
Houtzdale Pa
Thanks for looking,
Don
Mine did the same thing, but I live in the salt belt of central pa... that's exactly what I did thou, used flared ends to a union. I wouldn't use a compression union, I'm not a fan of those things.
hwrdbd
Ya def just get a piece long enough to stretch from your two closest unions, including all bends and whatnot. Hopefully you'll get lucky and not have to cut a piece. If you do, make sure you slide the fittings on before you flare it... ask me how I know... just zip tie your new line up alongside the old one best you can.
Godofdew11
all over
Thanks guys i flew home from Angola africa at 7 yesterday morning to get home to the GF telling me she had driven home from her moms with no brakes.. when my brother and father were a phone call away. going out to inspect the rest of the lines and see whether i should just man up and get a stainless kit and do the whole truck, or just replace this line for now. I am lucky and a good freind works at a shop and has the tool for doing double flare fittings so cutting it is not the worst ever.
Thanks for the relpies!
ryanss22
upstate central ny
If u have a friend with a flare tool. Spend the money on a 25' roll of the nickel line and be done forever. Thats what I did on my rebuild. Borrowed a buddys hyd flare tool and bam done.
ToMang07
Mainah!
Mine did it back in January, while I was plowing ~15" (+/-) of snow. I pinched off the line with some vice grips, and drove it for a week (gently) until I could get a new SS brake line installed. I figure it lasted 11-12 years in New England through salt... I'll just replace it and not worry about it. Chances are I won't still have it in 12 years.
Gary
South Lyon Mi
There is a company in Michigan that sells stainless line kits, I have done a few trucks with there kits and was very happy with them. I have also used that nickle-copper tubing to make lines, it is easy to work with, the stainless sucks to work with.
http://www.inlinetube.com/
