Brake pedal to floor.
CoastalF350
Was driving around last night and went to press the brakes and the pedal just went straight to the floor. Even when pumping it it would not build pressure. My fluid level is fine. Any ideas on what to check to cross out some potentials
webb06
Seneca, MO
Is everything still connected inside the cab?
Maybe a caliper came apart but you'd lose fluid if that happened.
CoastalF350
Everything is connected inside the cab... No loss of fluid. About to drive it home and check again
CoastalF350
ImageUploadedByTapatalk1421093986.557826.jpgfound it... No fluid
CoastalF350
What do you think is causing it? I know I need pads. But what about the fluid leak?
webb06
Seneca, MO
When the pads get down to nothing the cylinders in the calipers blow out causing the seals to bust and fluid to leak out.
