2good2Btru
Trying to get some of ideas from guys that have built their engines. What did you do to break your engine in? Do burnouts like Bigrpowr, LoL. Not but serious, u guys just drive it normal for a couple days, weeks so on.
This.Vary rpms and load. Don't hold wide open for the first 60-100miles. Loading the engine seats the rings which you want.
Add on to this question....what do you guys do for first fire up? Key off jump starter to build oil pressure or just fire it up normal since it will probably take a while to fire?
Wasn't the Zink additive only needed for cam break ins back when engines had flat tappet cams and lifters? Ive never used zink on roller motors because theres really no friction on the cam with a roller lifter. Ide think a normal oil would be fine.
What brand and weight of oil would you guys recommend using for break in.
you guys are wimps!!! pin it to win it!!
Generally the only thing i do is let it idle for a few minutes and check for leaks, let it get up to temp under a light load, check for leaks again... and then beat the *** out of it LOL
The engine thats in my reg cab got built, and put on a dyno less than 30 min after it ran.
Same thing we do with truck engines here, they get on the FULL load dyno right after they are rebuilt. Rings will seat no matter what.
