Lubbockguy1979
Leisurely driving to work today i hear a huge bang. Almost like a backfire. My first reaction was to hit the clutch take the truck out of gear (zf6 tranny manual tcase). Truck was making unusual vibrations as i slowed down and pulled off the road. Get in the bar ditch and leave the truck running in neutral. Engine sounds normal look for the obvious front or rear driveshaft broken gobs of fluid leaking. I see nothing out of the ordinary. Decided to attempt to limp on to work a few miles down the road. Put the truck in gear and have no movement. Get back out and double check the drivetrain. Again the driveshaft isnt spinning in gear at idle in 1st. Decided to kick it into 4 wheel and i have movement again. The truck is making pretty rough noises but made it to work. Im pretty sure the rear axle isnt the culprit since when in gear the rear shaft wasnt spinning. The tcase is a chain driven unit so for fourwheel to work the chain has to be intact as well as the transmission. About the only outher thing it could be is the output shaft breaking right? Gotta love old trucks with 337k on the clock.
Sent from my SAMSUNG-SM-G900A using Tapatalk
