BTS transmission E40d
Strokethis73
I have a BTS E40d that is in my 95 reg cab 4wheel drive truck. Trans has about 10,000 miles on it. Brian Set this trans up for about 450-500hp. Feel free to shoot me a call or text at 502-472-6955 for more info. Im sure I can get Patty or Tina to email you the build sheet on it. Also I am open to trades on equal value things. Asking price is 3k. I have receipts for 5500. Trans has always been ran with a temp gauge and aftermarket large trans cooler.
Strokethis73
I gave Brian the details on what the trucks set up was. He did what he thought was necessary, and put something behind the motor to match it.
Rideracelivemx7
Montana
interesting, when I bought my BTS private sale I called brian to ask the deal on it. he said if it was built with in the last 2 years it had the lastest and greatest(this was back in February) and it should hold 8-900HP and he said that with confidence.
04stroker
Sarasota-Bradenton, Florida
When I have talked to Brian he said for the most part all his transmissions are built alike. Not exactly but for the most part.
Chvyrkr
Sure, IF the VB is set up for that power.
Rideracelivemx7
Montana
ahhh cleared up, he did not mention anything about the valve body at the time. Excuse me while I call him to get an upgrade LOL
Strokethis73
The first one he built for me lasted 6 months, the second almost a year. Then, He got the point. I have a spare valve body and shift solenoid packs as well. they go with it.
lincolnlocker
Central Michigan
about the only thing different is the shaft material that he used.. old vs new
exactly, just different setting... he told me if i ever went up in hp to call him and he said he would walk me through the process while i was on the phone.
what broke?
live life full throttle
Chvyrkr
Aaaaand, what "point" would that be?
Strokethis73
First transmission he said it looked like a bomb went off inside of it. Everything was burnt up and I do believe one of the shafts broke. Second time I think the torque converter split. However he does not build the converters but he went ahead and rebuilt the transmission due to the upgrades the truck had gone through. I'm not a automatic transmission builder. So it's all foreign to me. The second valve body I have I'm sure he drilled some holes... Changed some shifting firmness.whatever he does. The truck has been sitting in my shop since mid to late 2012. Due to some engine problems.
Strokethis73
Just kept tearing things up. The trans that's in the truck now has been babied. Just drove it back in forth to work for a while
