*** built 6.4 drop in long block fs ***
AirFishAutomotive
DELAWARE
Like the title says, has about 2500 miles or so on it, never been races, beat on, sprayed
Motor is complete and still currently in truck, thinking about pulling it and putting back to stock for resale here are specs on engine
6.4 block, magnafluxed, line Honed, bored
.30 over Midwest delipped/flycut/coated pistons
R&r rods
Balanced bottom end
Motorcraft cam/crank/rod bearings
Rcd stg 3 billet cam
Elite billet flex plate
Elite Cnc ported heads, oversized intake/exhaust valves/o ringed/5 angle valve job/ elite valve springs
Arp head studs
Afa stage 2 intake
Manton lifters
Manton hd push rods
Oem rocker arm assembly
Motorcraft lpop
Motorcraft lpop cover
Front cover gasket
Motorcraft thermostats
Motorcraft oil cooler
Motorcraft front cover gasket
Rcd aluminum oil pan
Mpd ccv
Powdercoated hammer grey/black
Intake manifold/valve cover gaskets/rocker boxes
Complete drop in engine ready to take whatever power you want to throw at it, was going to be in a race truck and then put it in my dd and now going to sell it if I can find a new home, for what all you are getting the price isn't far off of a Ford stock reman long block, to take into consideration
No core needed, cash/certified check/credit card accepted
Will be selling the turbo set up etc (369) once engine sells as of now it's still in the truck and I'm driving it daily
Swap your fuel system/turbos on and your ready to go
Once paid for in full can have it pulled & shipped within 3-4 business days
12,500 firm shipped, A similar engine from online places is 19-23k without shipping or core
Call 302-875-2818 or pm, serious only. Tia
