Bunch of other stuff
NyCowboy87
Arkport, N.Y.
Custom Girdle with Studs, ties the pan reails in with the mains-$1200
Hypermax new style rods, one rod is brand new due to it being torched when the piston let go, all the others are good-$2500
Casserly 450/400's BRAND NEW this spring 300 miles on them, just had them checked out by him because of the piston faliure all are good-$2500
Cometic fire rings with ONE gasket you will need to call cometic for another gasket. These are nitrogen filled rings and are brand new-$250
Buyer pays shipping, if somone wants everything Ill make them a deal.
NyCowboy87
Arkport, N.Y.
Took a few pics of the stuff. The new rod from hypermax is still in the bubble wrap, just pulled it out of the box for the pic.
Magnum PD
VA
On the girdle, is there spacers for the height differences on the bearing caps. Do I need to modify the oil pan?
Magnum PD
VA
The girdle is about as close you can get to a bed plate as you can right?
NyCowboy87
Arkport, N.Y.
No building it to comply to the NADM Pro Street class that we run around here and the pulls Full Pull Productions puts on. That means 3.0 atmosphere in a twin setup.
