Buying a clutch kit question
chris89
Should I buy a flywheel with the valair kit. I have the solid flywheel it was good untill I put the bigger injectors in an its starting to slip. So what do you guys think I should do
Magnum PD
VA
A stock clutch probably won't last. Depends on what you are going to do with the truck.
chris89
I'm buying a valair. Wondering if I should buy the flywheel with the clutch
chris89
I can't have down time right now as this is my only ride.. I went ahead and bought the flywheel with the kit
