BW turbos
cap
Eastern Shore MD
so I'm going to have to replace the motor in my truck and am going to amp everything up. I think I want to put a BW turbo on but there are so many different kinds and what-not that I don't understand the sizing and stuff of them, can anyone break it down for me what each size is? ex..s363=.66 or whatever?
jake
thewrubelator
The Dirty Glove
Basically, the way the turbo sizing works, is compressor inducer size, turbine size, and A/R housing (exhaust housing). Most BW SX-E turbos are in Super core form, which means the compressor cover and turbo core is included, but you must purchase the exh housing separate. The A/R size is, simply put, the size of the exhaust housing (.90, 1.0, etc). For an example, an S363 SX-E turbo, has a 62.99 MM inducer, with a 73mm turbine.
Mdub707
Mohawk NY
If you let us know your power goals and how you use your truck, and maybe your budget we can recommend a turbo setup for you as well. Tons of helpful people on here.
