Camera not working
Tom@BigTimeKustomz
Bayville, NJ
So my camera hasn't worked in 3 weeks and I may have some time to look at it tomorrow. Have already di-electric greased the plug by the spare but no dice. Anyone else have this issue and what did you do to fix it?
Jeff6146
I sprayed out the connector with QD electronic cleaner and zip tied the connector real tight. Mines been good ever since. My Lincoln is the same way. Did the same thing
Tom@BigTimeKustomz
Bayville, NJ
Ok so pulled plugs off, sprayed with compressed air, applied dielectric grease and still nothing. Next try is pulling the tailgate off and seeing if there is a broken wire, which apparently is common. Will update if that's the culprit.
very common. the cool part it is a short harness that is available from Ford for a reasonable price.
Tom@BigTimeKustomz
Bayville, NJ
So camera is working. Shot some dielectric grease in original while I was waiting for new wiring harness to arrive from Sunrise. It's working now but if it fails again the wiring harness is on the shelf and can be installed in minutes.
