chappy
I was just wondering. Its the only explanation I have for my tune not working right. It started this spring when my truck started not running right when the temps got hot outside. I ended up pulling codes and seen I thru 2 codes for the accelerator pedal. I changed the pedal and it ran good after that kind of. The codes have yet to come back but the tune (spd) still wasn't working right. The turbo would go retarded and the vains would not let the turbo spool and wouldn't let it open up all the way once lit. I could hear it thru the exhaust it was that bad. Sounded like a stuck ebpv on a 7.3. I pulled the turbo out and all is fine. Thought for the heck of it I'd try the mpd tune and it works great. So I tried my srl+ and it works great as well. Go back to the spd and it does the same thing. So only thing I can think of is the tune got corrupted some how. Just didn't know how or if its possible. Truck ran great with it for months till the accelerator pedal went bad. I've got no ideas so I'm hoping someone else has heard of this before.
