Cast Aluminum E4OD / 4R100 Transmission Pan
Copperhead
Pikeville, KY
I have a "like new", MAC brand,..... (the same one that makes Headers & Exhaust systems), Cast Aluminum Trans Pan that I'd like to sell. I was going to hang on to it,......BUT,.... I see no need, where I sold one of my trucks and my other one already has a deep pan on it.
ANYWAY,.....
I ditched the black-oxide bolts that originally came with it and I'm including all BRAND NEW, Stainless Steel hardware.
The only thing you'll need to install it, is a new gasket. This is normally included when you purchase a filter kit. This pan holds 2-3 qts more fluid over stock, BUT,.....the way it's designed, it uses an original type 2wd filter,......NOT,... the longer (4x4) filter that has the extended snout for those stupid, deformed looking OEM, stamped steel 4wd pans.
$150 shipped (cont 48 ONLY)
