Check Valve For Fuel System
03cody
Bethany Illinois
I have one of Marty's fuel systems and I want to put a check valve or something between the sump and the pump so that I don't have to drain the tank anytime I have to change filters or do anything else.
Any recommendations on what to use or what to do?
Extended Power
Putting a check valve in between the sump, and pump would stop flow of fuel FROM THE PUMP to the sump....backwards to what you want...and I second the vote for a good 1/2" full port ball valve...3/4" is even better.
