Estrogen Hostage
- Joined
- Aug 12, 2011
- Messages
- 147
- Reaction score
- 0
Last night I was doing a compression check. The cab is off the truck, and both valve covers were off. The injectors were pulled out, and the oil drained from the cylinders. I cranked it over several timed to make sure the cylinders were clear.
So, I installed injectors on one bank of the engine, and pulled all four glow plugs. The second cylinder I got to shot oil out the other side of the engine with enough force to shoot the other valve cover off on the floor (it was just sitting there not bolted in). Why did cranking it over push oil into that other cylinder? Do you guys think I hurt anything?
