Chugging issue
bigbear5014
Hi i have a 06 ford f350 dually with the 6.0. Since i got the truck at around 70 to 75 mph at about half throttle you can feel a chugging coming from the motor like its either starving for fuel or air. I unplugged the maf sensor on the intake and nothing changed still the same issue. When i rebuilt the turbo there was a vgt vein broke which now the turbo runs fine. I had also replaced the banjo bolts with the 6.4 banjo bolts to help with fuel and still having a chugging issue. Any help is appreciated thank you
6speedsd
Olive Branch, MS
Need to check your fuel pressure, and get a quality scanner on it to watch some parameters.
