Cleaning out Shop. TONS OF RANDOM STUFF CHEAP.
NRHX2009
Elizabethville, PA
2 Like new BFG All Terrain 315/75/16 tires. Ran for most of this season but tires are in excelent shape, no chunks missing etc... $200 each
2 like new 36x14.5x16" Trxus STS Tires mounted on 16x12 Mickey Thompson Classic III wheels. 8x170 bolt pattern for Ford D60 Front. Wheels are Like new. With center caps. $900 for the pair
Terminator Dual HPOP Setup. I had them on my SD with 350/200's for a while, held 3k+ ICP. Blew an O ring connecting the remote IPR block. Replaced O-ring and havent run since. They were working fine prior to that. $1100 Shipped no cores needed.
2 Bad 7.3 PCM's APX-1 Dp441 and DAC3 DPC421 Make offer
1 Bad 7.3L IDM 110V Make offer
Tons of 6.0L Reman turbine housings. Fully cleaned, blasted, painted $60 each
6.0L Used VGT Solenoids. Some working some not. 20+ available. Make offer
Cummins P7100 13mm P Pump, all BOSCH internals, Quick rate cam, 850+cc $4500 with adjustable gear, no core charge.
T6 1.10 Turbine housings for 96x88 Borg Warner turbos. New modified I have over 15 available $550 each
7.3L ZF6 Main Shaft NEW OEM (PN: 131930409401) $250
Air Lift Towing air bags with brackets and air lines. Manual fill, no air compressor. Good Shape. Were on my 01 F350 dually, but would imagine they fit 99-03 F250/F350. $200
Superduty Windows, Supercab Small pop out windows and brackets on the sides $50 each, 2 available. Rear Sliding Window, has some wear but still works and sealed. $100
Dana 80 Mag Hytec Cover. Used in good shape with bolts $150
Stock 6.4 Exhaust system. No downpipe. Was on F450 CCLB $100 Pickup only
Pair of Sterling 10.5 Axle shafts from Mitchell Differential. Brand new. Upgraded but not sure on material. $250 for the pair.
Southbend ZF6 Dual Disc Sintered Iron Clutch. Few hooks on it since rebuild by Kennys Pulling Parts. $1000
7.3L ZF6 Kennys Pulling parts, Dual Disc Organic Clutch. Needs rebuilt. Worked very well for towing until you add to much hp it burns it up. $350
2" Aluminum Wheel spacers. 8x170 M14 fine thread studs. No lug nuts $75 for the pair.
PHP Chip. Used on a customers truck for 2 weeks and then returned it. Chip, cable, switch in case. $250
ALL PRICES ARE OBO plus shipping. Make any offers, worst I can say is no. PM or call. 717-919-7423
I will mark items sold as we go.
psduser1
on the road
Pm me your best price on the rear slider and the d80 maghytec cover, shipped to 48846.
Also, is the idm serviceable for a core? If so, add that in. If it's no good for a core, don't worry about it.
Please and thank you.
NRHX2009
Elizabethville, PA
Any offers on this stuff?
Also have a complete 5.9 Cummins to zf6 trans setup.
5.9 Cummins to zf6 Adapter plate
Triple sintered iron clutch
Zf6 4x4 trans
Manual Transfer case np 271
Ford zf6 trans crossmember
Driveshafts for cclb front and rear.
$4800 for everything.
