BWCbuilt
I have a 2wd 6.0 with a djm 3/5 as of current. I am looking to drop another few inches. What should I be looking for?
I'd guess the 2wd springs are like the 4x4 ones with different ratings for gas and diesel. I'd look at springs from a 5.4L gas 2wd truck. Like a 4800 or 4400lb spring, if there is such a thing on the 2wd. Pretty sure on the 4wd, they'll drop the front by an 1" to 1.5" without cutting coils.
Sent from my XT1080 using Tapatalk
They're going to have a softer spring rate. So it will soften up the front some, which you probably will not want. Probably better off cutting yours.
