Bushwakd
Going on the second year now with slow cranking on start up in cold weather. I have fresh batteries (DEKA brand) that are a year and a half old. New alternator when batteries were installed a year and a half ago. New Motorcraft glow plugs and relay were put in late spring this year. Injectors were freshened up by Swamps late spring this year. Compression was checked before injector install and was in the high upper 390-400 psi. Battery cables look to be in good shape with no corrosion.
What am I overlooking?
Today I disconnected the batteries and put a multimeter on them and got 12.53 volts on both. I then pulled the batteries before starting the truck and took them in to Advance Auto to test.Test turned out good. I took batteries home and put back in the truck and tried to crank it over and get a weak spin out of the starter. It starts but cranks slow. Once it is started it cranks over fine every time.
What I do notice is first start up of the day in cold weather I turn the key on and the dash battery gauge gets dragged down to 8 volts (glow plugs being energized and vacuum pump running and fuel pump running). I wait until all the power robbers are done sucking power and crank it over and the starter spins slow. I drove the truck to Advance Auto and they did a load test with the batteries installed and batteries pass, alternator passes, starter spins normal and passes.
Why does the starter spin slow on the first start of the day or after sitting for an extended period in cold weather but spins fine after that when everything has warmed up? The starter is the original starter and has 117,000+ miles and is over 12 years old and has never had extended cranking issues except for several injector installs.
I want to think the issue is the starter but why a slow cranking starter on initial start in cold weather but starts fine after that. Yes I can plug it in and it helps aid in starting but that does not answer the slow crank issue.
Have I figured out my own problem by narrowing it down to the starter?
I guess I need to pull the starter and have it tested next.
To simulate the slow cranking in cold weather do I need pull the starter out and put the starter in my freezer for 8-10 hours and then put it in a cooler with ice packs and then take it to my local starter rebuilder for testing to see how it reacts in cold weather.
