qcfarmer
- Joined
- May 24, 2011
- Messages
- 379
- Reaction score
- 0
Back in January I installed an aux fuel tank that filled my oem tank via gravity feed. I immediately noticed my oem fuel tank leaked around the fill tube, where the plastic nipple is. I don't know how long it was broken for because it is impossible to fill the oem tank to the very top. With the aux tank and gravity feed setup, it was obviously leaking. I went and replaced the oem tank with a new tank from ford. The setup has worked perfectly until yesterday when the oem tank started leaking from the plastic nipple again. Are these tanks known for this and is there something I can do so I don't end up having to replace tanks every 5 months. Thank you
