compounds 64 over 80
06f250powerstroke
ontario, canada
I ment s483 they were shawns but I had Jesse Warren go through them when they acted up
They run decent on the street keep it out of od unless your going 120 430 gears help out a bunch
Extended Power
Do they haze much when warm?
When I had 150 nozzles on my 285's, they were way too smokey for me...I sent them back to Jesse to change them to 100's.
I have haze with the 100's as well, but not nearly as bad.
TBagAMouseTrap
Windber PA
What turbos are you running? I was thinking of swapping to 285s and a bigger compressor wheel on my low pressure when I get a trans.
powerstrokedkid87
New Jersey
im running a cast 66/480 with the fuel I have currently there is enough
if I were to redo my setup, id probably look into the 369 and a 488 but I would need more fuel.
if you have the fuel for the setup, if go a little larger on the setup all together. but it depends what your using the truck for also.
Extended Power
There are a lot of people with way more experience than me that will tell you the 96mm turbine wheel does not have the power to turn the 88mm compressor to its full potential.
matt92idi
Maryland
Yeah I talked with James about that and he said the biggest s400 he would run is a s485. He said after that he would look into a s500 or other options
