compounds are running
fordfreak4life
check your plug ins on your oil cooler.... mine used to get a weird idle sometimes and i started playing with plug ins and found when i wiggled the plug ins on my oil cooler that i would smooth out so i spliced a plug in off a spare harness and havent had anymore problems
strokin6L
Springville NY
Agree with Shawn, there is no reason to have more fuel pressure than what is needed. 60psi is all i run and it never drops on a WOT run.
strokin6L
Springville NY
68-73 psi.
If that's all it's dropping to....that's even higher than what most set their PSI at. So seeing as it's dropping roughly 12psi on a WOT run...you can set fuel pressure at like 65psi and most likely it'll drop to around 53psi or so on a WOT run then. And 53psi is still above the minimum.
Redneck6.0L
i have the fass 150/150 and with my hybrids with 150% nozzles, i never drop evn 1psi, running 90psi is flat out stpid, a good way to blow orings
faster6.0
69 psi off the back of the heads. Looking good matt! Get that thing to the track!
Redneck6.0L
How long does it take for the turbo to lite. Did you get the email I sent with the fender well pics
Cutting-Edge Diesel
Newkirk, OK
It takes quite a wile for it to lite. I might change out the .83 on the 66 for a .70. Yeah I got it, thanks!
