compounds are running
Pizza pig
MD
Thats really not too bad if the gate is closed. Solid up pipes now?
Redneck6.0L
Is the 68 wheel you guys are talking about the same as the 65 wheel industrial uses
Extended Power
What is the measurement of II turbine inducer? (Since we already know the exducer is 65mm...and that its a 10 blade.)
Cutting-Edge Diesel
Newkirk, OK
still only making 45psi. Hooked air up to the intake and I have a leak in the valley of the motor. Might be a intake gasket or something. Might get into it this weekend and see if I find time.
Also got a tranny problem. Driving with the TC locked and slowly accelerating up to 70mph (like passing someone) The TC would unlock at 70 and RPMs would shoot up. After a few time of it doing it Tow/Haul was flashing, Pulled over and it was P01744. Any ideas?
MorganY
college station, tx
I believe that's the TCC mechanically stuck open. It should be a pump related issue. I had the same code after I rebuilt my tranny myself, it was a pump issue. Check line pressures maybe?
FX4 F2-Fifty
East Houston/San Marcos
OD clutches? Mine slips too but around 90mph, but if I let downshift it is fine.
Sent from my DROID BIONIC using Tapatalk
