If I have ten thousands shorter pistons what would be my compression ratio???
Jul 21, 2017 #1 J jtlane New member Joined Nov 9, 2015 Messages 71 Reaction score 0 If I have ten thousands shorter pistons what would be my compression ratio???
Jul 22, 2017 #3 Magnum PD Active member Joined May 18, 2011 Messages 9,566 Reaction score 6 Location VA Stock headgasket? Was this after a rebuild? That is to allow the mating surfaces to be machined down some. I don't think that's much to make any difference
Jul 22, 2017 #4 J jtlane New member Joined Nov 9, 2015 Messages 71 Reaction score 0 Yep stock head gaskets
Jul 23, 2017 #5 C C'roy78stroker Member Joined Sep 25, 2011 Messages 290 Reaction score 0 Location West Virginia No deck machining?
Jul 23, 2017 #8 Magnum PD Active member Joined May 18, 2011 Messages 9,566 Reaction score 6 Location VA Unless you have problems starting it, shouldn't be an issue
Jul 23, 2017 #9 J jtlane New member Joined Nov 9, 2015 Messages 71 Reaction score 0 Alright bud thank,you
