Blowby
- Joined
- May 22, 2011
- Messages
- 1,532
- Reaction score
- 0
Needed something to work on this winter so I started on the removal of the mechanical regulators for my waste gates and on to electronic. Created the mount and snap in holders on the 3D printer to allow me to make changes on the fly. The snap in holders are press fit into location holes on the mount. I wanted to eliminate printing the features that have been proven and only print the areas that need additional iterations. The mount will be changed as I start to finalize the location.
The two 1/8 NPT female fittings will hold the MAP sensors for each WG. HP and LP will be controlled independently.
The two male fittings on the back will be seeing regulated high pressure from either my Nitrous bottle or CO2 on one fitting and the other fitting will provide pressure to a line leading to the fitting under the diaphragm of the HP WG. This will hold down the diaphragm using the solenoids per controller. I will keep it next to the WG's on the passengers side by the AC unit. More pictures to come as this progresses.
