coolant leaking from head stud nut
TyCorr
Bad machine work? Maybe head surfacing equipment setup wrong?
Rusty
Yea and the heads could have been torqued incorrectly in sequence or torque values. Shoddy work no matter which way you slice it. Although Jake thinking he is a racecar driver doesnt help.
lincolnlocker
Central Michigan
oem that came in the rebuild kit.
lol. I live up to my Tapatalk signature very well.
live life full throttle
Arisley
Arlington, Texas
Make sure you check the head and the block to make sure they are flat. Straight edge (a level works good in a pinch) and feeler gauges.
are you gonna figure out if your cam gear is walking prior to reassembly?
lincolnlocker
Central Michigan
just fired her up. haven't stopped since I started yesterday. im going to bed. no I didnt get cam figured out. ill tare it down this winter...
lincolnlocker
Central Michigan
this was the first time doing this on a 7.3.... even though there was only 7000ish miles on these gaskets, how easily should the heads and gaskets came off when I pulled it apart?
