Coolant temp
Pwrcummins
Ok so I haven't gone around to getting my fan clutch replaced yet. Driving today I hear my fan roaring. Iv never heard that before. So that tells me my fan clutch is working. Could there be something else heating me up?
Pwrcummins
I'm bout done with this truck. I can't have a vehicle that doesn't get hot. I want to fix it but funds are tight. Is there an easy was to pull the radiator and maybe I can fix the fins on it? Will plugging in my egr valve make the fan work 100%? I know Iv prolly asked the same question earlier I'm just stressed with this issue.
Pwrcummins
Oh and one more thing don't know if EGTs play a part but I can hit 1400* with in seconds of wot.
DEEZUZ
NO PUKESTERS
NWI
Your radiator is possibly clogged. Can you. Measure the inlet and outlet temp?
DEEZUZ
NO PUKESTERS
NWI
Temp gun at both hoses. If there is a huge difference, iirc 20* or more, there is a flow issue
Pwrcummins
Well no flow issue. The pressure in the hoses are firm. Both feel the same temp. Don't have a temp gun unfortunately.
Radio
Gillette, WY
The fact that coolant temp was reading 30 degrees hotter than ambient temp and 20 hotter than oil after sitting over night makes me wonder if the coolant temp sensor isn't reading hot.
Sent from my XT1060 using Tapatalk
Pwrcummins
May be. I'm gonna swap that sensor and see. Could me runnin 40s make the coolant hotter than oil?
Radio
Gillette, WY
No the harder you work the engine the hotter the oil will get. That is why it uses coolant to cool the oil.
Pwrcummins
Well I'll start with the small fixes first and go from there before I spend a lot on something else
