Core Support
Sodbuster Jr.
Michigan
Upon inspection of my truck this afternoon, I noticed that my radiator core support was cracked. No big deal I'll just weld it up. So I yanked my grille to find out that the whole drivers side is completely rotted out. How big of a job is it to replace one of these? I plan on looking in a couple junkyards first. And also what else could I do to avoid this in the future?
Tom S
Amazing how nice those write ups are to have located.
Diesel_Brad
Gilbert PA
Good luck finding a GOOD used one. I had to replace the rad support in my lightning which is pretty much spotless due to rust//
Ford is the ONLY place to get a new one and they list for $711. EVERY aftermarket one that shows a listing is a LIAR. They send you a GASSER one which is COMPLETELY different than a diesel one
ytee
Agreed, don't buy the core support anywhere but Ford. I purchased one from LMC and it was way wrong. Good luck with finding a used support, I have never seen one that wasn't either cracked or rusted.
Chris
Sodbuster Jr.
Michigan
Thats what i have heard. I am having a good friend of mine that works at Ford check on prices. I looked at the core support alot closer yesterday afternoon and I am thinking maybe I can repair it. The passenger side is not rusting yet, but who is to say it stays that way. $711 is a dent in the pocket book. Would it be safe to weld it up and repair it for temporary use? I did one in a friends 86 F250, but that is an off road beater.
Pstroke96
Connecticut
patching it is fine as long as you keep everything where it is supposed to be, but i wouldnt patch it up as a permanent fix because it will rust out around the welds down the road
Diesel_Brad
Gilbert PA
like I said. that is list. NO ONE PAYS LIST. Your friend most likely gets 20-30% off. so it would be closer to $530
ytee
If you can find a dealer to deal with you, dealer cost is about 425.00.
Chris
Pstroke96
Connecticut
good point tom, sucks i didnt even know they could do that when i did mine i had to sucker up at the parts counter
