Craigslist find, opinions?
HeavyAssault
Middle, VA
Is $10k spending money for you or is that your life savings?
If you can "afford" to loose $10k it could be a decent deal if you do your research. Title/VIN check, OASIS, visual inspection, et etc.
I mean it's not my life savings but I by no means would take losing 10 k lughtly.
So basically it's new motor time if it drops a valve? Is there any ways to check without tearing it down, such as if I went down to look at the truck?
VetteD_SiN
i wouldnt. youre gonna drop 10k and instantly gonna have to work on it. not gonna be cheap, thats for sure. and like mentioned earlier, not like its a ranch or a plat or anything.
Jomax
Arizona
I wpuld steer clear. "It started running rough, so he bought a new truck"? Didn't even pay the money for a diagnostic?
JMart
DFW
This, he knows what was wrong with it and he was better off getting another truck.
Bustedknuckles
And since you drive an 04 class action lawsuite duramax for overheating yours overheats regularly?
Get lost.... before so much foam comes from your mouth you choke.
Dude where did that come from? I was just saying what i thought maybe it was as 11's have some problems dropping valves, a customer of ours got a engine under warranty at 30k for that. Btw mines a lb7, lly's had the issues with overheating....
Bustedknuckles
So it has washed out cylinder walls then....
I said i bet it has a dropped valve, a guess i made because 11's are known to drop valves and it suddenly started running rough but the guy is selling it instead of fixing it. If someone came onto a duramax site and said they were looking at a 03 that was blowing white smoke at idle i would say it probably had bad injectors, same difference... Seriously why are you jumping down my throat over this?
JMart
DFW
Look at his sig, its because he has an 11.
dangerous1
Anyone with any business sense knows you assume the worse until proven otherwise.
Sent from my VS876 using Tapatalk
